• | To specify performance preferences |
In addition, you can optimize performance by disabling or hiding certain features that you don’t need. For more information, see What settings do I use to ensure the optimal performance of Corel Painter?.
The performance preferences are described in the following table.
The number of Undo levels applies across all open documents. For example, if you set 5 undo levels and have two open documents, undoing three operations on the first document leaves you with only two undo operations on the second document.
• | Do one of the following: |
• | (macOS) Choose Corel Painter 2020 menu Preferences Performance. |
• | (Windows) Choose Edit Preferences Performance. |
