You can create your own paper texture by choosing a pattern and then modifying the spacing of the pattern elements. You can also modify the angle of the pattern elements to alter the direction of the texture.
You can create a paper texture from a selected pattern.
You can also create a paper texture by selecting an area of an image and converting it into a paper texture.
A paper texture was generated by selecting an area of the image (left). An example of applying a brushstroke to the canvas using the new paper texture (right).
1 . |
Choose Window Media Panels Papers. |
2 . |
In the Papers panel, click the Make Paper button . |
3 . |
In the Make Paper dialog box, choose a pattern from the Pattern list box. |
Moving the Spacing slider to the right opens up the space between rows and columns in the selected pattern. It also increases the size of the pattern. |
Moving the Angle slider changes the direction of the texture rows. |
2 . |
Choose the Rectangular Selection tool from the toolbox. |
4 . |
In the Papers panel, click the Capture Paper button . |
The Make Fractal Pattern feature and certain weaves also produce excellent paper textures. For more information, see Creating fractal patterns.
