You can quickly see whether the currently selected brush can take advantage of your system's multi-core processor (CPU), AVX2 extensions of the CPU, or graphics processor (GPU) technologies. You can also run the Brush Accelerator to evaluate your system and optimize application settings.
You can disable your system's GPU for the currently selected brush, allowing you to experiment with performance settings.
The Performance panel also lets you know if your system's GPU has been disabled for all brushes or if the number of cores allocated to Painter is insufficient. For more information, see Performance preferences.
1 . |
Choose Window Brush Control Panels Performance. |
2 . |
Enable the Disable GPU for this brush check box. |
1 . |
You can also run the Brush Accelerator utility from the Welcome Screen (Help
Welcome Screen).
