This topic describes some of the reasons why a brushstroke may not appear:
• | Main color — In the Color panel, what color is the Main Color (front) swatch? Is it a color that will show up when applied to your image? If not, click the Main Color swatch, and then set a different color. |
• | Opacity — Check the Opacity setting on the property bar and, if necessary, adjust the pop-up slider to increase opacity. |
• | Brush method — The brush method determines the basic nature of a brush. To check the brush method, choose Window Brush Control Panels General. If you’re drawing with a light color on a dark background, the method must be set to Cover in order to show the lighter color. |
• | Drawing mode — When you make a selection, the drawing mode determines what part of the selection is protected. For more information, see Choosing the protected area of a selection. |
For more troubleshooting tips, see My brushes stopped working.
