This effect creates a blur similar to the distance from the plane of camera focus in photography. You can specify the radius of the blurring effect in the image.
The "M" is a floating shape. The blur on the shadow was created by using Depth of Field.
There are five different methods for applying Depth of Field:
Paper — applies the effect by using the paper texture luminance (brightness) as a mapping model. More of the effect is applied to the dark areas in the paper grain; less of the effect is applied to the light areas. If you want to experiment with the effect, keep the Papers panel open while you apply the effect. This way you can switch to different papers and modify the paper controls. |
Image Luminance — uses the image’s luminance as the model for the effect. More of the effect is applied to dark areas in the original image; less color is applied to light areas. |
Original Luminance — uses the luminance of the clone source (or a pattern) as the model for the effect. More of the effect is applied to dark areas in the clone source (or pattern); less color is applied to light areas. |
Alpha Channel or Layer Mask — sets the values in the channel or layer mask as the model for the effect. More of the effect is applied to dark areas in the layer mask or channel; less color is applied to light areas. You can use this method only if you have a saved alpha channel or a layer mask in your image. |
2 . |
Choose Effects Focus Depth of Field. |
3 . |
Choose Uniform Color from the Using list box. |
1 . |
Choose Window Paper Panels Papers. |
4 . |
5 . |
Choose Paper from the Using list box. |
2 . |
3 . |
Choose Image Luminance from the Using list box. |
To use a clone source, choose Window Clone Source. In the Clone Source panel, click the Open Source Image button , and Open Source to choose a clone source. |
To use a pattern, choose Window Media Library Panels Patterns, and click a pattern swatch from the Pattern library panel. |
3 . |
3 . |
4 . |
Choose Original Luminance from the Using list box. |
Min Size — sets the minimum radius of the blur regions |
Max Size — sets the maximum radius of the blur regions |
