You can adjust the dye concentration in an image to control color intensity and play with surface texture. For example, use this effect to lighten an underexposed photo or to darken an overexposed one. You need to choose a method for applying the effect. Some methods, such as Paper, generate more texture than other methods, such as Uniform Color. There are five different methods for applying dye concentration:
Paper — adjusts color by using the paper texture as a mapping model. If you want to experiment with the effect, keep the Papers panel open while you apply the effect. This way you can switch to different papers and modify the paper controls. |
Image Luminance — uses the image’s brightness as the model for the color adjustment |
Original Luminance — uses the luminance of the selected pattern or clone source as the model for the adjustment |
Alpha Channel or Layer Mask — sets the values in the alpha channel or layer mask as the model for the dye concentration adjustment. You can use this method only if you have a saved channel or a layer mask in your image. |
2 . |
Choose Effects Surface Control Dye Concentration. |
3 . |
Choose Uniform Color from the Using list box. |
2 . |
3 . |
Choose Image Luminance from the Using list box. |
1 . |
Choose Window Paper Panels Papers. |
4 . |
5 . |
Choose Paper from the Using list box. |
To use a clone source, choose Window Clone Source. In the Clone Source panel, click the Open Image button , and Open Source to choose a clone source. |
To use a pattern, choose Window Media Library Panels Patterns, and click a pattern swatch from the Pattern library panel. |
3 . |
4 . |
Choose Original Luminance from the Using list box. |
2 . |
Presets — the controls in this area let you choose a preset effect, save the current settings as a preset, and delete a preset |
Maximum — controls the amount of dye on the peaks of the texture |
Minimum — controls the depth of the texture. The lower the values, the higher the contrast between the peaks and valleys. The higher the values, the flatter the image appears. |
Preview — enable this check box to preview the effect in the document window |
Reset — resets the sliders to their default settings |
