The Adjust Selected Colors effect is similar to the Adjust Colors effect, but it works only on a specified range of colors within an image. You choose a color in an image and adjust colors within a range of that color. You could, for example, change yellow peppers to red peppers. You can adjust colors that are exactly the same as the color you select, or you can choose colors within a range, based on proximity (on the color wheel or the color space) to the selected color.
Selective color adjustments change only certain colors in the image.
The Extents sliders determine the extent of the HSV color space around the selected center color.
By combining these settings, you can set up a very specific range of colors to adjust. For example, you can limit changes to a precise shade of red.
The Feather sliders affect the softness at the edge of the selected colors. These sliders can help you create smoother transitions between the replaced color and the original.
A replaced color with and without feathering.
You can choose from any of the following adjustment methods:
Paper — uses the selected paper grain to control the color adjustment |
Image Luminance — uses the luminance of the image as the model for color adjustment. Areas of greater luminance are adjusted more. |
Original Luminance — uses the luminance of the clone source as the model for color adjustment. If you have not set up a clone source, the current pattern is used. |
Choose Effects Tonal Control Adjust Selected Colors. |
The Adjust Selected Colors dialog box appears. |
The Color panel displays the selected color as the main color. |
Choose Uniform Color from the Using list box. |
Choose Window Paper Panels Papers. |
4
5
Choose Paper from the Using list box. |
Choose Image Luminance from the Using list box. |
To use a clone source, choose Window Clone Source. In the Clone Source panel, click the Open Image button , and Open Source to choose a clone source. |
To use a pattern, choose Window Media Library Panels Patterns, and click a pattern swatch from the Pattern library panel. |
4
H Extents — controls the number of hues adjusted. Only hues within the specified percentage of hues on the color wheel are adjusted. |
H Feather — controls the softness at the edge of the selected hues |
S Extents — controls the range of saturation adjusted. Only saturations within this range are adjusted. |
S Feather — controls the softness at the edge of the range of saturated colors |
V Extents — controls the range of values adjusted |
V Feather — controls the softness at the edge of the selected values |
Moving the Extents sliders to the right increases the amount of color space affected and creates smoother transitions between the replaced color and the original. |
Hue Shift — adjusts the colors of the pixels by changing their hue. Moving the slider to the right increases the hue. |
Saturation — adjusts the amount of pure hue in the color. Moving the slider all the way to the left creates a grayscale image. |
Value — adjusts color brightness. Moving the slider to the left darkens colors. |
Reset — resets the sliders to their default settings |
