Corel Painter includes a series of preset lighting effects that you can apply to your images. The lighting effects allow you to quickly change the intensity or direction of the image lighting. You can apply a preset lighting environment without making any changes, or you can use it as a starting point for customized lighting. For more information, see Adding, deleting, and repositioning light sources or Adjusting light properties.
Before (left) and after (right) applying a preset lighting effect.
Choose Effects Surface Control Apply Lighting. |
In the Apply Lighting dialog box, click a preset thumbnail. |
If you apply an effect to a shape, dynamic layer, text layer, or reference layer, you must first commit the layer to an image layer.
