For general information about using effects, see Common options for effects.
This section contains the following topics:
| • | Applying preset lighting effects |
| • | Adding, deleting, and repositioning light sources |
| • | Adjusting light properties |
| • | Using paper to create texture |
| • | Using 3D brushstrokes to create texture |
| • | Using image luminance to create texture |
| • | Using clone source or pattern luminance to create texture |
| • | Creating embossed effects |
| • | Using channels and layer masks to create texture |
Adjusting surface texture using lighting effects
| • | Creating reflection maps |
| • | Adjusting texture lighting |
| • | Applying the Apply Screen effect |
| • | Applying the Color Overlay effect |
| • | Applying the Dye Concentration effect |
| • | Applying the Express Texture effect |
| • | Applying a warp effect |
| • | Applying the Woodcut effect |
| • | Applying the Distress effect |
| • | Applying the Serigraphy effect |
| • | Applying the Sketch effect |
