You can use the Sketch effect to generate a black and white pencil outline of a photograph. You can then use the outline as a guide for applying color, which is a useful technique for starting a painting. For more information, see Choosing a painting workflow.
To store the settings for the effect, you can create a preset. This allows you to quickly apply the settings to another image.
Before (left) and after (right) applying the Sketch effect.
Choose Effects Surface Control Sketch. |
In the Sketch dialog box, adjust any of the following sliders: |
Sensitivity — determines sensitivity to detail. Low values detect only the main edges. High values detect the main edges as well as thin lines, such as the lines around a person’s eyes. |
Smoothing — determines how much noise is filtered out. Higher values result in wider, lighter, and blurrier lines. |
Grain — determines how much of the paper grain is revealed in the sketch marks. Move this slider to the right to show more of the paper grain. |
Threshold — removes noise after edge detection. Threshold high is used to flag light pixels which may be just noise in the image. Threshold low is used to test surrounding pixels. |
In the Sketch dialog box, modify any of the settings. |
4
In the Save Preset dialog box, type a name in the Save As box. |
