You can use the currently selected image’s luminance, or lightness, to produce surface texture. Light parts of the image create dents; whereas darker parts create raised areas. The overall effect gives an embossed look to the image.
Before (left) and after (right) adding texture based on image luminance.
Choose Effects Surface Control Apply Surface Texture. |
Choose Image Luminance from the Using list box. |
4
Adjust the Softness slider to control the amount of distortion created by the texture. |
5
In the Appearance of Depth area, adjust any of the following sliders: |
Amount — controls how much surface texture is applied to the image. Moving the slider all the way to the right applies the maximum amount. |
Picture — controls how much of the color from the original image is applied to the texture. At 100%, the full color of the picture shines through. Moving the slider to the left displays more black, leaving only the shine. |
Shine — controls how much highlight appears on the surface of the texture. Higher Shine values make the texture look metallic. |
Reflection — maps a clone source image or pattern onto the texture at a variable percentage |
6
In the Light Controls area, adjust any of the following sliders: |
Exposure — adjusts the overall lighting amount from darkest to brightest |
