You can add texture to an image by incorporating paper texture. This allows you to give the appearance of depth to brushstrokes. Corel Painter uses the paper surface and grain to produce the effect. You can choose a specific paper texture, or Corel Painter applies the currently selected paper texture to the image by default.
If you want open to experiment with the effect, keep the Papers panel open while you apply the effect. This way you can switch to different papers and modify the paper controls.
Before (left) and after (right) creating texture by using paper grain.
Choose Window Paper Panels Papers. |
4
Choose Effects Surface Control Apply Surface Texture. |
5
Choose Paper from the Using list box. |
6
Adjust the Softness slider to control the amount of distortion created by the texture. |
7
In the Appearance of Depth area, adjust any of the following sliders: |
Amount — controls how much surface texture is applied to the image. Moving the slider all the way to the right applies the maximum amount. |
Picture — controls how much of the color from the original image is applied to the texture. At 100%, the full color of the picture shines through. Moving the slider to the left displays more black, leaving only the shine. |
Shine — controls how much highlight appears on the surface of the texture. Higher Shine values make the texture look metallic. |
Reflection — maps a clone source image or pattern onto the texture at a variable percentage |
8
In the Light Controls area, adjust any of the following sliders: |
Exposure — adjusts the overall lighting amount from darkest to brightest |
