With the Serigraphy effect, you can use photographs to generate images that appear silk-screened or like woodblock cuts. When applying the effect, Corel Painter saves each color reduction as a separate layer, so you can edit each layer individually.
Before (left) and after (right) applying the Serigraphy effect.
Choose Effects Surface Control Serigraphy. |
In the Serigraphy color dialog box, adjust any of the following sliders: |
Smoothing — determines the smoothness of the black edge |
Threshold — determines the total amount of color difference from the center color |
Dist Weighting — determines the amount of color distance from the center color |
Hue Weighting — determines how much hue contributes to the effect |
Sat Weighting — determines how much saturation contributes to the effect |
Lum Weighting — determines how much luminance contributes to the effect |
4
Click the Match Color chip, and choose a color from the Color dialog box. |
5
Click the Fill Color chip, and choose a color from the Color dialog box. |
6
Click Create Serigraphy Layer. |
You can also specify Match and Fill Colors by clicking a color in the image.
