You can generate an image that appears embossed by cloning the image and then using the luminance of the clone source to produce the effect. You can control the height of the texture, as well as the lighting, color, and material properties of the embossing.
Before (left) and after (right) applying the embossed effect.
5
In the Fill dialog box, enable the Current Color option. |
6
Adjust the Opacity slider to set the opacity of the fill. |
8
Choose Effects Surface Control Apply Surface Texture. |
9
Choose Original Luminance from the Using list box. |
10
In the Light Controls area, adjust any of the following sliders: |
Exposure — adjusts the overall lighting amount from darkest to brightest |
11
Enable a Light Direction option to change the location of highlights and shadows. |
