Corel Painter Help :
Image hose : Creating a 3‑Rank nozzle
You can create a 3-Rank nozzle using the grid method.
This nozzle file has three items in Rank 1, three items in Rank 2, and three items in Rank 3.
Painting with the 3-Rank nozzle "Broken Shells."
Choose Window Navigator to display the Navigator panel, and check the height of the current nozzle file. |
8
In the Layers panel, select the canvas. |
11
Choose Edit Paste, and position the pasted layer in the area you added. |
12
Choose the Layer Adjuster tool from the toolbox, and select both layers in the Layers panel. |
14
Choose File Save, and save the file in RIFF format. |
15
Choose File Get Info, and edit the nozzle definition in the File Information dialog box. |
For example, the nozzle definition "Image hose 3 by 3" describes a 2-Rank nozzle with three image elements (items) in Rank 1 and three image elements in Rank 2. Suppose the new nozzle has three image elements in Rank 3. To paint with images from all three ranks, you need to change the nozzle definition to "Image hose 3 by 3 by 3". |
To paint with your new nozzle file, you first need to load it. For more information, see To load a 1-Rank nozzle file.
