Color Expression Controls
Color expression determines whether Corel Painter should use the main or additional color in an image. Using color expression, you can introduce input (such as direction) which controls output when you apply two-color brushstrokes.
To display the Color Expression panel Back to Top
Choose Window Brush Control Panels Color Expression.
To set Color Expression controls Back to Top
In the Color Expression panel, choose one of the following options from the Expression list box:
None — applies no adjustment to the color expression
Velocity — adjusts the color expression based on the dragging speed
Direction — adjusts the color expression based on the direction of the stroke, and according to the value you set with the slider or in the box
Pressure — adjusts the color expression based on stylus pressure
Wheel — adjusts the color expression based on the wheel settings on an airbrush stylus, specifically the Wacom Intuos Airbrush stylus
Tilt — adjusts the color expression based on the angle of the stylus from the tablet
Bearing — adjusts the color expression based on the direction in which the stylus points
Rotation — adjusts the color expression based on the rotation of the stylus
Source — adjusts the color expression based on the luminance of the clone source
Random — adjusts the color expression at random
If you want to switch the main and additional colors, click the Invert button .
