In early 2012, a Corel Painter companion application will be available for the iPhone and iPad. In anticipation of this launch, an option was added to the Preferences dialog box that allows the future companion application to connect to Corel Painter.
| To allow a companion application to connect with Corel Painter |
1 |
Do one of the following:
(Mac OS) Choose Corel Painter 12 menu |
(Windows) Choose Edit |
2 |
Enable the Allow Companion Application to Connect to Painter check box.
3 |
Type a name in the Service Name box to give your copy of Corel Painter a unique
name.
We recommended that you do not enable the Allow Companion Application
to Connect to Painter check box before the companion application is available.
You can also specify an Authentication Code to ensure that only a legitimate
user can access your copy of Corel Painter from a remote application.
