Computed Circular Controls
The Computed Circular controls allow you to specify the tip profile of brushes using the Computed Circular dab type. For example, you can customize the dab opacity and hardness, which controls the color density at the outer edge of the dab.
To customize a Computed Circular dab profile Back to Top
Choose Window Brush Control Panels Computed Circular.
Perform a task from the following table.
To
Do the following
Modify dab opacity
Move the Dab Opacity slider to the left to reduce the opacity. Move it to the right to increase the opacity.
Control the color density at the edge of the dab
Move the Dab Hardness slider to the left to reduce the color density and create a soft dab. Move it to the right to increase the color density and create a hard dab.
