Corel Painter lets you create custom palettes that contain only the features that you want so you can quickly access them. For example, you can place items from the Brush library panel or any of the Media library panels in a custom palette. If the item that you want is represented on a panel with an icon, you can create a custom palette simply by holding down Shift and dragging the icon out of a panel to the application window. This method works for brush variants, paper textures, media, such as gradients and patterns, and nozzles, looks, and scripts. You can also add commands from the main menus or panel options to a custom palettes.
Items that appear on a custom palette are references (aliases or shortcuts) to the original. This means that if you change the original — for example, by modifying and saving a brush variant — the custom panel button loads the newest version. However, if you delete the original, Corel Painter won’t be able to find the item again to load in the custom palette.
Custom palettes behave like the standard panels. For more information about working with panels, see Working with Panels and Palettes.
| To create a custom palette |
1 |
Choose Window |
2 |
Choose New from the Add To list box.
3 |
With the Add Command dialog box open, do one of the following:
Choose a menu item from a default Corel Painter menu.
Choose a menu item from the Other menu to add additional controls to a
custom palette.
Choose a menu item from the Panel Menus menu to add a panel, or any of the
items included in a panel’s Options flyout menu, to a custom palette.
Choose a menu item from the Tools menu to add a Toolbox tool to a custom
palette.
4 |
In the Add Command dialog box, click Ok.
You can also create a custom panel by pressing Shift and dragging a button to
You can add brush variants that are stored in different brush libraries to the
same custom palette. When you choose a brush variant from the custom
palette, the brush library in which the brush variant is stored is automatically
loaded in the Brush Library panel. This allows you to quickly switch between
brush libraries.
| To open or close a custom palette |
Perform a task from the following table.
To
Do the following
Open a custom palette
Choose Window
Close a custom palette
On the custom panel header bar, click the Close button.
| To add items to a custom panel |
Tools from the main toolbox cannot be added to a custom panel.
