If you regularly work with documents that contain similar dimensions, formatting, and resolution, you can create document templates so that you don’t have to start each document from scratch. When creating a template, you can add content to the canvas and save it as part of the template.
| To save a document as a template |
1 |
Create a file with the sizing, formatting, and resolution attributes you want.
2 |
Choose File |
3 |
In the Save (Mac OS) or Save Image As (Windows) dialog box, save the file to one
of the following folders in your user folder:
(Mac OS) Corel Painter 12\Support Files\Templates
(Windows 7) AppData\Roaming\Corel\Painter 12\Default\Templates
If you want the template to display under File |
In a multiuser environment, only users with Administrator status can add files
to the Templates folder.
In Windows, you need to ensure that all hidden files are displayed in order to
access the AppData folder.
| To open a document template |
Choose File |
You can also open a template by choosing Help |
