Corel Painter lets you completely customize your workspace to suit your workflow needs. You can customize Brush Libraries, Paper Libraries, and Portfolios and save these changes to use later. In addition, you can easily create multiple workspaces, each with different libraries and portfolios. You can even share these customized workspaces with others by importing or exporting them.
| To create a new workspace |
1 |
Choose Window |
2 |
Type a name in the Workspace Name text box.
3 |
From the Based On list box, choose the workspace on which you want to base the
new workspace.
4 |
Click Save.
The application switches to the new workspace. |
| To switch to a different workspace |
Choose Window |
| To import a workspace |
1 |
Choose Window |
2 |
Choose the workspace file that you want to import.
3 |
Click Open.
| To export a workspace |
1 |
Choose Window |
2 |
Choose the workspace that you want to export.
3 |
Click Save.
| To revert to the default workspace |
Choose Window |
Corel Painter lets you modify the default workspace, so this workspace may
eventually differ from the factory default workspace. If you restore the factory
default workspace, you will lose all customizations unless you save the
workspace.
