Editing Library Resources
You can rename items in libraries to suit your preference. You can also delete an item from a library, including a default library. However, can can restore the default library to the factory settings. For information, see Restoring Default Libraries.
To rename a library resource Back to Top
In a library panel, right-click the resource that you want to rename, and choose Rename [Resource]. (e.g. Rename Paper)
In the Rename dialog box, type the new name in the Rename [Resource] text box.
To delete a library resource Back to Top
In a library panel, click the resource that you want to delete.
Click the Delete [Resource] button.
Do not delete default resource files or folders.
