Editing Scripts
Corel Painter lets you edit your scripts by modifying script instructions.
Modifying Script Instructions
You can edit a script by opening the Script list, which displays the script as a series of instructions that contain parameters. You can edit most of these parameters.
To edit script parameters Back to Top
In the Scripts panel, click the script that you want to edit from the Script library viewer.
Click the Scripts Options button , and choose Edit Script.
Corel Painter displays the script’s instructions in the Script list.
In the Script list, expand the instruction that you want to edit.
4
Double-click a parameter within the instruction.
5
In the parameters dialog box, make the necessary changes.
6
Close the dialog box.
7
Click Done to save the changes to the script.
The open script becomes the current script and is displayed in the Script library viewer. If you choose another script from the Script library viewer, the open script does not change.
You can also edit a script by exporting the script and then opening the script file in a text editor. You can export a script by clicking the Scripts Options button in the Script panel, and then choosing Export Script.
