You can erase any part of your image and control the opacity of erased areas. You can also link the opacity to stylus pressure or specify a fixed opacity value.
You can set the Eraser opacity to Hard (left) or Soft (right).
| To erase an image area |
1 |
In the Layers panel, choose the layer on which you want to erase.
2 |
Choose the Eraser tool |
3 |
On the property bar, adjust the Size pop-up slider |
4 |
Click one of the following buttons:
Soft Mode |
Hard Mode |
You can toggle between Soft Mode and Hard Mode by holding down Option
(Mac OS) or Alt (Windows) as you drag in the image window.
You can erase in straight lines by clicking the Straight Line Strokes button |
You can also erase image areas by choosing the Brush tool |
