Jitter Controls
The Jitter control introduces a randomized jitter to the brushstroke. Instead of appearing directly along the stroke, dabs appear randomly outside the brushstroke path. You can also set an expression setting to further control the Jitter effect. For more information, see Expression Settings.
Brushstrokes with Jitter set to 0 (top) and 3.13 (bottom)
To set jitter Back to Top
Choose Window Brush Control Panels Jitter.
Move the Jitter slider to the left to decrease deviation from the stroke path, or to the right to increase the deviation.
If you want to use an expression setting, choose a setting from the Expression list box.
