Modifying the Display of Library Panels
You can modify the appearance of the library panels by changing the way they are organized and displayed. You can resize a library panel to control the space that it takes in the application window. You can also change the display size of the resource icons. If you do not need to use some of the resource swatches, you can hide them. In addition, if you create a new resource, you can create a custom icon for the resource.
To modify the display of a library panel Back to Top
Open a library panel.
Perform a task from the following table.
To
Do the following
Resize the library panel
Point to the edge of the panel. When the cursor changes to a double-sided arrow, drag the edge of the panel to resize it.
Resize the library swatches
Click the library panel’s Options button , choose [Resource type] Library View, and choose one of the following options:
Small
Medium
Large
Display the library swatches as a list
Click the library panel’s Options button , choose [Resource type] Library View, and choose List.
Hide a library swatch
Right-click a library resource swatch, and choose Hide [Resource type].
Unhide all swatches
Click the library panel’s Options button , choose [Resource type] Library View, and choose Show All Hidden Items.
Customize a swatch icon
Right click a resource swatch, and choose Set Custom Icon. Choose the drive and folder where the image is stored. Click the image file and click Open.
