You can modify the appearance of the Brush Library panel by changing the way brushes are organized and displayed. This allows you to set up the Brush Library panel to best suit your needs. For example, you can hide the recently used brushes to give you more space. In addition, you can also hide brush categories and variants to expose the brushes that you use most. You can also rename variants and restore variants to their default settings if you modified their attributes using the brush controls.
| To modify the Brush Library panel |
1 |
Click the Brush Selector on the Brush Selector bar.
2 |
In the Brush Library panel, perform a task from the following table.
| To modify the display of brush categories and variants |
1 |
2 |
| To rename brush categories and variants |
1 |
2 |
To
Do the following
Rename a brush category
Right-click a brush category, choose Rename Category, and type a name for the category.
Rename a brush variant
Right-click a brush variant, and choose Rename Variant, and type a name for the variant.
| To restore a default brush variant |
1 |
2 |
Click the brush category of the brush variant that you want to restore.
3 |
Click the brush variant.
4 |
In the Brush Library panel, click the Brush Library Options button |
If you want to restore all brush variants to their default settings click the Brush Library Options button |
You can also restore a default brush variant by clicking the Reset button |
