Performing Offset Sampling
Offset sampling, also known as “point-to-point cloning,” lets you sample an area of an image and then reuse it elsewhere within the document, or in separate document. Sampling is a useful technique for retouching photographs.
To perform offset sampling, you must set a sampling reference point and then set destination reference points. Sampling reference points specify the area of the document that you want to reuse, or clone. Destination reference points determine the area where you want the sampled image to appear. To identify which area of the source document you are sampling, you can turn the crosshairs cursor on.
The green dot (left) represents the sampling reference point. The red dot (right) represents the destination point.
It is important to note that the sampling reference point, also know as the source, is not treated as a clone source. The sampled area does not display in the Clone Source panel.
To perform offset sampling within a document Back to Top
Click the Rubber Stamp tool in the toolbox.
If you want to adjust the size of the sampled area, type a value in the Size box, or adjust the slider on the property bar.
Hold down Option (Mac OS) or Alt (Windows), and click to set the source reference point.
A green marker appears on the image, indicating the reference point for the source image.
Hold down Option + Shift (Mac OS) or Alt + Shift (Windows), and click to set the destination reference point.
4
Apply brushstrokes to the destination area to reveal the sampled area.
You can disable offset sampling by clicking the Clone Color button in the Color panel or by clicking the Brush Selector on the Brush Selector bar, and choosing a non-Cloner brush variant.
You can also
Adjust the clone color opacity
On the property bar, type a percentage in the Opacity box, or adjust the slider.
Adjust the randomized jitter of the brushstroke
On the property bar, type a value in the Jitter box, or adjust the slider.
You can also enable offset sampling by clicking the Cloner tool in the toolbox.
You can set the destination area before painting by clicking while holding down Option + Shift (Mac OS) or Alt + Shift (Windows). A red marker indicates the destination area.
To perform offset sampling between documents Back to Top
Open both the image that you want to use as the sampling source and the image that you want to use as the destination.
If you want to view both images at once, you may want to arrange the images side-by-side.
With the source image selected, click the Cloner tool in the toolbox.
If you want to change the brush variant, click the Brush Selector, and click a Cloners brush variant in the Brush Library panel.
Hold down Option (Mac OS) or Alt (Windows), and click the source document to set the sample source area reference point.
A green numbered marker appears on the image to indicate the reference point for the source area.
4
Hold down Option + Shift (Mac OS) or Alt + Shift (Windows), and click the destination document to set the destination reference point.
5
In destination document, apply brushstrokes to the canvas.
You can also
Adjust the size of the brushstroke
Type a value in the Size box, or adjust the slider on the property bar.
Control the amount of color that is replenished in a stroke
On the property bar, type a percentage in the Resat box, or adjust the slider.
Control how much the brush colors smear underlying colors, including the paper color
On the property bar, type a percentage in the Bleed box, or adjust the slider.
Adjust bristle separation
On the property bar, type a value in the Feature box, or adjust the slider. The higher the setting, the farther apart the bristle hairs will appear.
Scale the brushstroke proportionally with the brush size
Click the Scale Feature With Brush Size button on the property bar.
To change to the crosshair cursor for sampling Back to Top
Do one of the following:
(Mac OS) Choose Corel Painter 12 Preferences General.
(Windows) Choose Edit Preferences General.
In the Preferences dialog box, enable the Display Crosshairs To Identify Rubber Stamp Sampling Source option.
The crosshairs indicate which area of the original image you’re sampling as you paint.
