Saving a Look
A look retains all brush variant settings, plus the paper, pattern, gradient, or nozzle settings. For example, if you customize a brush variant and paper texture to achieve a specific effect that you want to use in the future, you can save these settings as a look. When you save a look, it is added to the Look Libraries panel.
A brush variant is not itself associated with information about underlying texture or other elements. The look, on the other hand, is associated with additional information about a particular variant. Regardless of a document’s current libraries, when you select a look, you use the elements that are part of that look.
To save a look Back to Top
Choose Window Media Library Panels Looks.
Create a look by choosing a brush variant, and any additional settings that you want to save with the look.
Apply a brushstroke to the canvas.
4
Click the Rectangular Selection tool , press Shift and drag to select a square portion of the image or brushstroke, so you can use it as an icon for the look.
5
Click the Brush tool in the toolbox.
6
Click the Looks Library Options button , and choose Save Look.
7
In the New Look dialog box, type a name for the look in the Save As text box.
The new look appears as the last item in the Brush Looks panel.
To apply a saved look Back to Top
From the Media Selector bar, click the Look Selector button.
Choose a look from the Brush Looks panel.
Corel Painter loads the correct variant and materials for the saved look.
Paint in the document window.
