In Corel Painter, the property bar displays options for the currently selected tool. By default, the property bar displays in the application window docked below the menu bar, but you can close it. You can also move the property bar or dock it to the application window or to other panels.
The property bar for the Grabber tool.
From the property bar you can access and change tool options and settings. Tool settings are retained when you switch from one tool to another. You can also use the property bar to restore the default settings of the selected tool.
| To open or close the property bar |
Choose Window |
You can also close the property bar by clicking the close button on the header
bar.
| To move or dock the property bar |
Perform a task from the following table.
| To reset the default tool settings |
Click the Reset Tool button on the property bar.
The Reset Tool button on the property bar has the same icon as the selected tool in the toolbox. |
Various Reset Tool buttons for the Grabber property bar.
