Using Brush Loading
For greater color accuracy while cloning, you can use the Brush Loading option. This causes the brush to pick up individual colors in different regions of the brush dab.
Without Brush Loading, the Clone Color option uses a single, averaged color from the source for each brush dab. This results in an approximation of the original. You can use the Clone Color button without Brush Loading to create an artistic impression of the source.
To enable the Brush Loading option Back to Top
Choose Window Brush Control Panels Well.
In the Well panel, enable the Brush Loading check box.
