Using Lighting
The Apply Lighting effect lets you shine one or more light sources on an image. Using this effect is like hanging your artwork in a gallery and adjusting colored spotlights to illuminate it. You can choose different lighting effects from the Corel Painter library, or you can create your own effects by defining brightness, distance, color, and other characteristics.
Before (left) and after (right) Apply Lighting.
Applying Preset Lighting Effects
The Lighting library contains several preset lighting environments. You can use these directly or as a starting point for customized lighting.
To apply preset lighting effects Back to Top
Select a layer or area of the canvas.
If you want to apply the effect to the entire image, do not make a selection.
Choose Effects Surface Control Apply Lighting.
In the Apply Lighting dialog box, click a preset thumbnail.
The lighting effect is displayed in the Preview window.
Creating Custom Lighting
You can use the controls in the Apply Lighting dialog box to add, delete, and position light sources. You can also set light properties to create unique lighting effects.
The Preview window shows the current position of each light source and the angle of its projection.
The four steps to creating custom lighting are
Adding or deleting light sources
Positioning lights
Setting light properties
Saving light settings
Adding, Deleting, and Repositioning Light Sources
The lighting effect is created by applying light from different sources to the image. You can add or delete as many light sources as you wish. Your only limit is your system’s memory.
When you add a light source, a new indicator appears in the preview window. The small part of the light indicator is the origin (the point from which the light is shining). The large part of the indicator is the point toward which the light is shining.
The type of lighting effect you create is determined by the position of light on the image. You can use the light indicators to move and direct light sources.
Light source indicator.
To add, delete, or reposition a light source Back to Top
Perform a task from the following table:
To
Do the following
Add a light source
Click anywhere in the Preview window.
Delete a light source
Click an indicator, and press Backspace.
Move a light source
Drag the large end of the indicator to the point where you want the light to originate.
Change the direction of a light
Drag the small end of the light indicator until the light is pointing in the desired direction.
Setting Light Properties
You can set light properties such as brightness, distance, elevation, and color. Light properties have a cumulative effect. For example, if you turn up a light’s brightness, you might need to adjust exposure.
To change a light’s properties Back to Top
In the Preview window, click an indicator to select it.
Adjust any of the following sliders:
Brightness — is like a dimmer knob. Moving it to the left turns down the light source; moving it to the right increases brightness.
Distance — controls how far the light is from the image. If you move the light source closer, you can compensate for the increased light by adjusting the Exposure slider to compensate.
Elevation — sets the light’s angle in relation to the canvas. At 90°, the light is shining straight down, and at 1°, it’s nearly horizontal.
Spread — sets the angle of the light cone
Exposure — controls the image’s brightness, as in photography. Moving the slider to the left decreases exposure and darkens the image; moving it to the right increases exposure and lightens the image.
Ambient — controls the surrounding light in an image. If you have no individual lights in your image, the ambient lighting governs the overall lightness of the image. Moving the slider to the left darkens the overall lighting; moving it to the right increases the light.
To change light color Back to Top
In the Preview window, click an indicator.
Click the Light Color chip, choose a color from the Color dialog box, and click OK.
4
Click the Ambient Light Color chip, choose a color from the Color dialog box, and click OK.
