Using Quick Clone
You can use Quick Clone to automatically set up everything you need to clone an image. When you use Quick Clone, it automatically:
creates the clone document
embeds the clone source
closes the source image
clears the canvas
enables tracing paper
selects a cloner brush
You can also change the Quick Clone preferences, which lets you customize the cloning process. For example, you can choose to always use the last selected cloner brush variant or leave the source image open.
To clone an image using Quick Clone Back to Top
Open the image that you want to clone.
Choose File Quick Clone.
Apply brushstrokes to the canvas by using the selected cloner brush.
If you enabled the Switch to Cloner Brushes check box in the Preferences dialog box, the last Cloner brush that you used is automatically selected.
To customize Quick Clone behavior Back to Top
Do one of the following:
(Mac OS) Choose Corel Painter 12 Preferences Quick Clone.
(Windows) Choose Edit Preferences Quick Clone.
Perform a task from the following table.
To
Do the following
Close the image that was used as the clone source
Enable the Close Source Image check box.
Open the Clone Source panel automatically
Enable the Open Clone Source panel check box.
Start painting in the clone colors on a clear canvas
Enable the Clear Canvas check box.
Activate tracing paper
Enable the Turn On Tracing Paper check box.
Activate the last Cloner brush variant
Enable the Switch To Cloner Brushes check box.
Use the current brush variant to clone the underlying color
Enable the Clone Color check box.
To enable the Clone Color check box, you must disable the Switch to Cloner Brushes check box.
