The Layout Grid provides an easy way to divide your canvas so that you can plan your composition. For example, you can divide your canvas into thirds vertically and horizontally to use the compositional rule of thirds. From the Layout Grid panel, you can access grid settings, such as the number of divisions, size, angle, color, and opacity of the grid. You can adjust these settings while you work and save them as a preset for future drawings and paintings. You can also move the grid to a new position.
The Layout Grid also lets you divide the canvas into compositional sections based on the proportions of the canvas. This nonprinting grid is used primarily for composing artwork before you begin drawing or painting.
The Layout Grid helps you compose images.
| To show or hide the Layout Grid |
Choose Canvas |
You can also show or hide the grid by clicking the Layout Grid tool |
You can also show or hide the grid from the Navigator panel by clicking the
Open Navigator Options button |
| To set Layout Grid options |
1 |
Choose Window |
In the Layout Grid panel, ensure that the Enable Layout Grid check box is enabled. |
2 |
Perform a task from the following table.
You can also set some Layout Grid options by clicking the Layout Grid tool
| To save Layout Grid settings as a preset |
1 |
In the Layout Grid panel, modify the settings you want, and click the Add Preset
button |
2 |
In the Add Preset dialog box, type a name for your preset in the Preset Name box.
3 |
Click Save.
The preset appears in the Type list box. |
You can also save a preset by clicking the Layout Grid tool |
| To delete a Layout Grid preset |
1 |
In the Layout Grid panel, choose the preset you want to delete from the Type list
box.
2 |
Click the Delete Preset button |
You can also delete a preset by clicking the Layout Grid tool |
| To choose a Layout Grid preset |
In the Layout Grid panel, choose a preset from the Type list box.
| To move a Layout Grid |
1 |
In the toolbox, click the Layout Grid tool |
The cursor changes to a hand icon |
2 |
Drag the grid to a new position.
