Viewing Selections
You can turn a selection on or off. You can also show or hide the selection marquee. The marquee is the visible border of the selection.
Turning Selections On and Off
You can turn a selection off and reactivate it when you need it later.
To turn off a selection Back to Top
Choose Select None.
You can also turn off a selection by clicking outside it with the Oval Selection tool , the Rectangular Selection tool , or the Lasso tool .
To reactivate a selection Back to Top
Choose Select Reselect.
This command is available only if you have turned off a selection.
Hiding and Showing the Marquee
You can control the display of the selection marquee.
To hide or show the selection marquee Back to Top
From the menu bar, choose one of the following:
Select Hide Marquee.
Select Show Marquee.
The drawing mode remains in effect even when the marquee is hidden.
