Corel Painter uses color sets to organize groups of colors. Some color sets are organized by both name and color relationship. Corel Painter provides several color sets — Corel Painter Colors, Mac OS and Windows system palettes, and the PANTONE MATCHING SYSTEM are a few. You can open any of the available color sets, choose a color from the color set, and then apply it to a brushstroke. You can open multiple color sets at a time.
In addition, you can import a color set to access additional colors. For example, you import a color set that you created in a previous version of Corel Painter.
If you need to find a specific color in a color set, you can search for the color by name or have Corel Painter find the color that comes closest to matching the current color.
Color Sets panel
To display the Color Sets panel | ![]() |
Choose Window ![]() ![]() |
To open a color set | ![]() |
In the Color Set Libraries panel, click the Color Set Options button ![]() |
To choose a color from a color set | ![]() |
In the Color Set Libraries panel, click a color.
To import a color set | ![]() |
1 |
In the Color Set Libraries panel, click the Import Color Set button ![]() |
2 |
In the Select Color Set dialog box, do one of the following:
(Mac OS) Click the Color Sets folder, choose a color set, and click Open.
(Windows) Choose a color set, and click Open.
To find a color in a color set | ![]() |
1 |
In the Color Set Libraries panel, do one of the following:
Click the Search for Color button ![]() |
Click the Color Set Options button ![]() |
2 |
In the Find Color dialog box, do one of the following:
Enable the By Name option, and type a name in the box.
Enable Closest to Current Color.
3 |
Click Begin.
4 |
Click OK when the desired color is found.
If the color set is visible, Corel Painter surrounds the found color with a selection frame. |
If you search for a color by name, but a color with that name is not found, the OK button is not available (it is grayed out). |
