Both the Real Watercolor and Watercolor brushes paint into a watercolor layer, which enables the colors to flow and mix and absorb into the paper. In Corel Painter, you can edit the Watercolor layer as you would any other layer without changing anything in the image layer. For example, you can draw pencil outlines in the image layer and then overlay watercolor shading without smudging the pencil lines.
You can sketch on one layer and paint with watercolors on a separate Watercolor layer.
You can transfer, or lift, information from the canvas to the Watercolor layer. This is useful if you want to apply Watercolor effects to a photograph. You can also wet the Watercolor layer, which activates a diffusion process.
To create a new Watercolor layer | ![]() |
1 |
Choose Window ![]() |
2 |
In the Layers panel, click the Layer Options button ![]() |
If you select a Real Watercolor or Watercolor brush variant from the Brush
Library, a Watercolor layer is automatically created when you apply a
brushstroke to the document window.
To transfer the canvas to a Watercolor layer | ![]() |
1 |
Open the image that you want to convert to a watercolor in the document window.
2 |
If the image contains multiple layers, you can drop all of the layers onto the canvas by clicking the Layer Options button ![]() |
3 |
In the Layers panel, click the Layer Options button, and choose Lift Canvas to
Watercolor Layer.
Once the layer content is lifted from the canvas, the canvas is blank. |
To wet the Watercolor layer | ![]() |
1 |
2 |
To work with a dry surface, click the Layer Options button ![]() |
