Getting Started with Printing
Corel Painter offers a wide range of printing options for various output devices. You can preview and size the image before you print it.
Setting Up Printing
Options for setting up your file for printing depend on several factors: the type of output device to be used, whether the printed output will be in color or in black and white, and whether you are printing separations.
To access print settings Back to Top
Choose File Page Setup.
Sizing an Image
If you want to print an image that is larger than a selected page size, you can size the image to fit the page. For example, when this option is enabled, a 12-by-12-inch image would be resized to fit on an 8.5-by-11-inch page.
To size an image to fit the page Back to Top
Choose File Print.
Click the Painter tab.
Enable the Size to Fit Page check box.
To print images larger than the page size, you must enable the Size to Fit Page check box.
Printing an Image
After choosing options in the Print Setup dialog box (Mac OS) or the Page Setup dialog box (Windows), you are ready to print your image.
To print an image Back to Top
Choose File menu Print.
The Print dialog box appears.
If you are using the Mac OS, choose Corel Painter from the list box below the Presets list box.
If you are using the Windows OS, click the Painter tab.
In the Print Type area, choose one of the four print types that Corel Painter supports.
If your printer is not a PostScript printer, enable the Color QuickDraw (Mac OS) or GDI Printing (Windows) option. Some common examples are the HP Deskjet, the Canon Bubble Jet, and the EPSON Stylus. You cannot print separations to printers that lack PostScript capability. Examples of such printers include the Hewlett-Packard Deskjet, the Canon Bubble Jet, and the EPSON Stylus.
To print an image to a color PostScript device, enable the Color PostScript option.
To print separations, enable the Separations option. The output consists of four pages, one each for cyan, magenta, yellow, and black. You can print separations from Corel Painter with PostScript devices, including high-resolution imagesetters. Corel Painter places a color bar, registration marks, and the color name on each of the four separated plates.
To print an image to a black-and-white PostScript laser printer, enable the B & W PostScript option.
  Some features described in the Help are available only in Corel Painter 12, and are not included in Painter Lite. Visit www.corel.com/painter for more information about Corel Painter 12.
