Using the Mirror Painting Mode
In Corel Painter, you can create a symmetrical painting by using the Mirror Painting mode. When you enable the Mirror Painting mode, a plane appears in the drawing window that lets you paint one half of an object while Corel Painter automatically replicates a mirror image of the opposing side of the object by reproducing the brushstrokes. For example, if you want to paint a symmetrical face, simply paint one half of the face and Corel Painter automatically completes the other half.
When using the Mirror Painting mode, the brushstrokes that you apply on one side of the plane may occasionally look different in the opposite plane. For example, if you start the Mirror Painting on a canvas that contains previously applied brushstrokes, the mirrored brushstrokes blend with the colors that are already on the canvas. In addition, if you’re applying randomized brushstrokes, such as a nozzle, the mirrored brushstokes are also randomly applied.
The green line that displays in the middle of the document window represents the mirror plane.
You can display the mirror plane vertically, horizontally, or display both at the same time. You can also control the placement of the mirror plane in the drawing window by moving or by rotating the plane.
To create a mirror painting Back to Top
In the toolbox, click the Mirror Painting tool .
On the property bar, click any of the following buttons:
Vertical Plane — positions the mirror plane vertically in the drawing window
Horizontal Plane — positions the mirror plane horizontally in the drawing window
Click the Brush Selector on the Brush Selector bar.
4
In the Brush Library panel, click a brush category, and click a brush variant.
5
Apply a brushstroke on either side of the mirror plane.
To
Do the following
Disable mirror painting mode
Click the Toggle Mirror Painting button on the property bar.
Reset the mirror plane to the default position
Click the Reset Mirror Painting button on the property bar.
The Brush tool is the only tool that you can use to create mirror and kaleidoscope paintings. Other tools, such as the Shape tool, are not supported.
To control the display of the mirror plane Back to Top
Perform a task from the following table.
To
Do the following
Specify an angle of rotation
On the property bar, type a value in the Rotation Angle box.
Rotate the plane in the drawing window
Point to a plane until the cursor changes into a rotation angle cursor , and then drag to rotate the plane.
Change the plane position
Point to over the center point of the plane until the cursor changes into a four-headed arrow , and then drag the plane to a new location in the drawing window.
Change the color of the plane
Click the Symmetry Plane Color button, and click a color swatch.
  Some features described in the Help are available only in Corel Painter 12, and are not included in Painter Lite. Visit www.corel.com/painter for more information about Corel Painter 12.
