Creating images
There are two types of computer graphics: raster and vector. With Corel PaintShop Pro, you can create both types of images. You can also create an image with both raster and vector layers. For more information, see “Creating images” in the Help.It is important to understand the differences between these two data types before you begin working with them.
Raster graphics
Raster images are composed of individual elements, called pixels, which are arranged in a grid. Each pixel has a specific location and color. If you magnify raster data, you can see the individual pixels as squares of colors. Raster images contain a fixed number of pixels, so when you magnify the image you are magnifying the display size of the pixels. As a result, raster images may display jagged rather than smooth edges when magnified on screen or when printed at a large magnification.
An object in a raster image is defined by its pixels. For example, the front door in an image of a house is made up of a mosaic of pixels at certain locations in the image. In bitmap images, you edit pixels rather than objects or shapes.
Raster images can display subtle changes in tones and colors, so they are most often used for images like photographs and digital artwork.
Vector graphics
Vector graphics use geometric characteristics — lines, curves, and their locations — to define objects. For example, a door in a graphic of a house is made up of a rectangle that has a certain width and height, is placed at a specific location, and is filled with a certain color. In vector images, you edit objects or shapes rather than pixels.
Vector graphics do not lose clarity or detail when they are scaled or printed, regardless of the change in size or resolution. For this reason, vector graphics are suited to technical illustrations or corporate logos.
Choosing to work with raster or vector data
With Corel PaintShop Pro, you create and edit raster and vector data on separate layers. With some tools you create raster data (like brushstrokes with the Paint tool), and with other tools (like the Text and Preset Shapes tools) you can choose whether you want to create raster or vector data.
In general, it is best to use a vector object if you need to edit it as an element separate from other parts of the image. For example, if you add a star to an image, you may want to change its size, color, or location. You can make these changes more easily if the star is a vector object. You can create raster data on separate layers, which can be easily edited or moved.
To apply tools or commands to vector objects that work only on raster data (such as the painting tools or the Effects commands), you can create a raster selection of a vector object and then paste the selection to a new raster layer.
Understanding image size, resolution, and color depth
Before you create a new image, you need to consider how you will use it. For example, will you display the image on a website, send it as an e-mail attachment, or print it? How you use the image helps you determine its size, resolution, and color depth.
Image size is represented by the physical dimensions of the image. When you create a new image or resize an existing image with Corel PaintShop Pro, you can define image height and width in pixels, inches, millimeters, or centimeters.
The following are guidelines for choosing a unit of measure:
If you plan to print the images, use inches or centimeters. By
starting with the final image dimensions, you can produce an
image that fits the page.
If you plan to export the images to another application (such as a
word-processing application), and then resize and print them, you
can use any of the options.
If you plan to display the images on the screen, use pixels.
You can resize an image after creating it, but doing so may result in loss of image data. For more information about resizing images, see Retouching and restoring images.
Image Resolution is measured in pixels per inch (ppi) or pixels per centimeter. Low resolution can cause pixelation, a problem in which large pixels produce coarse output. High resolution can increase an image’s memory requirements without producing a proportional increase in its quality.
Color Depth is measured according to the number of colors that a pixel can display. Each pixel’s color information is stored in bits — from 1 to 48 bits. In a 1-bit image, each pixel can display only one of two colors (black or white). In a 24-bit image, each pixel can display 1 of 16 million colors. Images with a color depth of 16 million colors look good, but they also require more memory to store and edit. Not all computer monitors can display 16 million colors, so some file formats limit the number of supported colors. For example, GIF images, a popular format for the Web, contain up to 256 colors (8-bit depth).
Many of the commands in Corel PaintShop Pro for applying effects and correcting images work on 16 million–color images only. Therefore, it’s best to create most images in 16 million colors. When you have finished working on the image, you can decrease its color depth and save it in another format.
You can create an image by using the New command in the File menu, or by copying aspects of an existing image. When you use an existing image as the source of your new image, you can copy the entire image or an individual layer. You can also create an image from any graphic data copied to the Clipboard from Corel PaintShop Pro.
When you create a new image in Corel PaintShop Pro, you can specify its dimensions, resolution, and type. The options available depend on the type of graphic you want to create. If you’re uncertain as to what type of graphic you need for your project, or which settings to choose, review the information in the following procedure. For more information about creating Art Media graphics, see Painting and drawing with the Art Media tools.
| To create an image |
Edit workspace
1 |
Choose File |
The New Image dialog box appears. |
2 |
In the Image Dimensions group box, type or set values for the
following controls:
Units — specifies the unit of measure
Width — specifies the width of the new image
Height — specifies the height of the new image
Resolution — specifies number of pixels contained in the chosen
unit of measure
If you want to choose preset dimensions, choose an option from the Load Preset drop-list. |
3 |
In the Image Characteristics group box, choose one of the
following options:
Raster Background — suitable for most graphics and painting
tasks
Vector Background — suitable for vector graphics
Art Media Background — lets you use the Art Media tools
4 |
Choose an option from the Color depth drop list.
If you chose the Raster Background option, you can choose a background color for the image by clicking the color box and choosing a color from the Material Properties palette. To choose a transparent background (for 8-bit or 16-bit images only), mark the Transparent check box. |
If you chose the Art Media Background option, you can choose a canvas texture from the Select the canvas texture drop-list. If you want to choose a color for the canvas, mark the Enable fill color check box, click the color box, and choose a color from the Color dialog box. |
5 |
Click OK.
The Memory Required field displays the amount of memory
required for the image. Your computer’s available memory
should be at least two to three times the value displayed in the
Memory Required field. To reduce the memory requirement,
you can reduce the resolution or the dimensions of the image.
For more information on choosing colors or materials, see
Using the Materials palette.
| To duplicate an image |
Edit workspace
1 |
Open the image you want to duplicate.
2 |
Choose Window |
A new window containing a copy of the image appears in the workspace. |
| To create an image from a layer |
Edit workspace
1 |
On the Layers palette, click the layer you want to copy.
2 |
Choose Edit, and click one of the following:
Copy
Cut
The current layer is placed on the Clipboard. |
3 |
Choose Edit |
A new window containing the layer appears in the workspace. |
| To create a new image from a layered image |
Edit workspace
1 |
2 |
Choose Edit |
All layers are copied to the Clipboard. |
3 |
Choose Edit |
A new image window appears in the workspace. The new image contains all layers merged into one raster layer. |
| To create an image from the Clipboard contents |
Edit workspace
1 |
Copy a selection or layer of an image, or an item from another
program.
2 |
Choose Edit |
The Clipboard contents are pasted as a new image. |
If the Paste As New Image command is grayed out, then the
data you have copied to the Clipboard cannot be pasted as a
Corel PaintShop Pro image.
A dialog box may appear and request additional information,
such as the width and height of the new image window. You
can change your preferences so that Corel PaintShop Pro does
not prompt you for size and options when you paste data. For
more information about setting file format preferences, see
Setting file format preferences.
