Creating layers
You can create a layer from the Layers palette. When you create a layer, you can specify properties such as the layer type, opacity, or blend mode. These properties can be modified as you work with the layer. You can also create layers from selections, vector objects, or other images.
Layers are created automatically when you use the Text tool, Art Media tools, or vector drawing tools, such the Pen tool or the Preset Shape tool.
| To create a layer from the Layers palette |
Edit workspace
1 |
On the Layers palette, click the layer above which you want create
a layer.
2 |
From the drop-list on the toolbar of the Layers palette, choose a
layer type:
New Raster Layer
New Vector Layer
New Art Media Layer
New Layer Group
New Mask Layer
New Adjustment Layer
3 |
Adjust the available controls for the layer properties.
4 |
Click OK.
The new layer is added above the active layer. It is named with the layer type and a number, such as “Vector 1.” |
For more information about renaming layers, see Renaming
layers.
Only grayscale and 16 million–color images can have multiple
raster-based layers (Vector layers are the only non raster-based
layers). When you add a new raster-based layer to an image of
another color depth, such as a 256-color indexed image,
Corel PaintShop Pro automatically converts it to 16 million
colors.
You can create a layer quickly by holding down Shift, and
choosing an option from the New Layer drop-list.
| To create a raster layer from a selection |
Edit workspace
Choose Selections |
The new layer is named “Promoted Selection.” |
When you promote a selection, some pixels surrounding the
selection border may be included, especially if the selection is
anti-aliased or feathered. For information about cleaning up a
selection before you copy or promote it, see Modifying
selections.
You can also create a raster layer by choosing Edit |
| To create a vector layer from vector objects |
Edit workspace
1 |
On the Tools toolbar, choose the Pick tool |
2 |
Choose Edit |
3 |
Choose Edit |
| To create a layer from another image |
Edit workspace
1 |
In the image window, click the image you want to copy for the
new layer, and choose Edit |
2 |
Click the image on which you want to paste the new layer, and
choose Edit |
The layer is pasted on the center of the canvas in the second image. |
You can also drag a layer from the Layers palette and drop it
onto an image.
