Creating masks
You can create a mask from an image by loading the image file from disk. When you use an image as a mask for another image, Corel PaintShop Pro applies the mask as a grayscale image. The source image is not altered. You can also create a mask by customizing one of the sample masks included with Corel PaintShop Pro.
An example of an image used as a mask
You can use a selection to create a mask that shows or hides the selection. You can use this mask as a starting point for creating artistic effects.
An example of a selection used as a mask
You can also create a mask from a channel by first splitting an image into its RGB, HSL, or CMYK channels. Corel PaintShop Pro creates a grayscale image for each channel. You can use one of these channel images to create a mask for the original image or for another image.
An example of the grayscale channel used as a mask
| To create a mask layer |
Edit workspace
1 |
On the Layers palette, choose the layer that you want to mask.
2 |
Choose Layers |
Show All — shows all underlying pixels
Hide All — hides all underlying pixels
You can paint on the image to show portions of the underlying
layer. For information about editing the mask, see Editing
masks.
For information about stacking layers, see Changing the order
of layers in an image.
| To create a mask from an image |
Edit workspace
1 |
Open the image that you want to use as a mask.
2 |
3 |
Choose Layers |
4 |
Open the Source Window drop-list, and choose the image.
5 |
In the Create Mask From group box, choose one of the following
options:
Source luminance — determines the degree of masking based
on the luminance value of the pixel color. Lighter colors produce
less masking; darker colors produce more masking. Transparent
areas completely mask the layer.
Any non-zero value — applies masking without gradation. Pixels
with an opacity between 1 and 255 pixels become white;
transparent pixels become black. Transparent areas completely
mask the layer.
Source opacity — determines the degree of masking based on
the opacity of the image. Fully opaque pixels produce no
masking; partially transparent pixels create more masking;
transparent pixels produce full masking.
If you want to reverse the transparency of the mask, mark the Invert mask data check box. |
6 |
Click OK.
The mask layer and the selected layer are added to a new layer
group. The mask layer applies to the selected layer only.
For information about editing a mask, see Editing masks.
To display the mask on the image, click the Highlight mask area
button |
To apply the mask layer to all underlying layers, drag it from the
layer group to the main level on the Layers palette.
| To create a mask from a selection |
Edit workspace
1 |
Make a selection on a layer by using the Selection tool |
2 |
Do one of the following:
To mask the selection, choose Layers |
To mask everything except the selection, choose Layers |
If you apply a mask layer to the background, the background is
automatically converted to a raster layer.
For information about editing masks, see Editing masks.
| To create a mask from a channel |
Edit workspace
1 |
Choose Image |
Split to RGB
Split to HSL
Split to CMYK
2 |
Select the grayscale image in which you want to create the mask.
3 |
Choose Layers |
4 |
In the Source Window drop-list, choose the channel that you
want to use for the mask.
5 |
In the Create Mask From group box, choose the Source luminance
option.
If you want to reverse the transparency of the mask data, mark the Invert mask data check box. |
6 |
Click OK.
The mask layer and the selected layer are added to a new layer group. The mask layer applies to the selected layer only. |
For information about editing the mask, see Editing masks.
For information about color channels, see Working with colors
and materials.
