Drawing lines
You can draw straight lines, freeform lines, and line segments. You can edit the nodes in a line to create curves.
You can also adjust the line options of existing vector objects.
| To draw a line segment |
Edit workspace
1 |
On the Tools toolbar, choose the Pen tool |
If you want to place the line segment on the current vector layer, mark the Create on Vector check box on the Tool Options palette. If no vector layer exists, marking this check box creates one for the line segment. If this check box is unmarked, the line segment is placed on a raster layer. Placing a line segment on a vector layer makes it easier to edit. |
2 |
On the Materials palette, click the Foreground and Stroke
properties box, and choose a color for the outline.
3 |
If you are drawing connected line segments and you want to
apply a fill, click the Background and Fill properties box, and
choose a color for the text fill. If you do not want the line
segments to have a fill, click the Transparent button |
If you are drawing a single, unconnected line segment, it is not necessary to choose settings from the Background and Fill properties box. |
4 |
On the Tool Options palette, click the Draw Lines and Polylines
button |
5 |
Choose a line style from the Line Style drop-list.
6 |
Type or set a line width (in pixels) value in the Width control.
7 |
Drag in the image window to create the line.
8 |
On the Tool Options palette, click the Apply button |
You can save your settings in the Tool Options palette settings
for subsequent use. For more information about saving settings
as presets, see Using and creating presets.
| To draw a curved or straight line |
Edit workspace
1 |
2 |
On the Tool Options palette, click the Draw Point to Point
button |
3 |
4 |
Do one of the following:
To create a straight line, click where you want the next node.
To create a curved line, click and drag. When the curve is the
right shape, release the mouse button.
If you want to draw lines at fixed angles (45 degree increments), hold down Shift as you drag. |
| To draw a free-form line |
Edit workspace
1 |
2 |
On the Tool Options palette, click the Draw Freehand button |
3 |
| To draw line segments |
Edit workspace
1 |
2 |
On the Tool Options palette, click the Draw Line and Polylines
button |
3 |
