Editing contours and paths
You can edit the contours and paths of vector objects. You can join contours by connecting their end points. You can also reverse the direction of paths and contours. The direction of a contour flows from the start node to the end node. When you place the cursor over the start node, a “START” message appears next to the cursor. When you place the cursor over the end node, an “END” message appears. If the object has a closed path, a “CLOSE” message appears.
You can duplicate contours.
For more information about the different types of nodes, see Modifying lines and curves.
| To join two contours |
Edit workspace
1 |
On the Tools toolbar, select the Pen tool |
2 |
On the Tool Options palette, click the Edit Mode button |
3 |
Select one of the contours you want to join.
All of the nodes in the object are displayed. |
4 |
Select the start or end node of the first contour you want to join.
You can only join contours in the same object. |
5 |
Hold down Shift, and select the start or end node of the second
contour.
6 |
Right-click, and choose Edit |
You can also join contours manually. Drag a node on the first
contour over the second contour’s start or end node. When the
cursor displays “JOIN,” release the mouse button.
| To break a contour at a node |
Edit workspace
1 |
2 |
3 |
Select the node where you want to break the contour.
4 |
Right-click the node, and choose Edit |
The path or contour breaks and a new node is added on top of
the current node. The node square changes to a node-on-node
indicator |
| To move a path |
Edit workspace
1 |
2 |
3 |
Drag any contour in the path.
| To move a contour |
Edit workspace
1 |
2 |
3 |
Hold down Shift, and move the cursor over the contour until the
cursor displays “SUB.”
4 |
Drag the contour.
You can also move a contour by double-clicking a node to
select all nodes, and then dragging one of the nodes.
| To reverse a path or contour |
Edit workspace
1 |
2 |
3 |
Click on a contour or path.
4 |
Select a node.
If you want to reverse multiple contours, select one node from each contour. |
5 |
Right-click the path or contour, choose Edit, and then choose one
of the following:
Reverse Path
Reverse Contour
| To duplicate a contour |
Edit workspace
1 |
2 |
3 |
Select one or more nodes.
4 |
Choose Objects |
Duplicate — copies the selected contour and pastes it directly
on top of the original contour
Duplicate & Offset — copies the selected contour and pastes it
at an offset from the original contour. The default offset is 10
pixels in the X and Y directions.
You can adjust the offset from the original contour by adjusting
the settings in the Duplication X and Duplication Y controls on
the Tool Options palette.
| To delete a contour |
Edit workspace
1 |
2 |
In the Tool Options palette, click the Edit Mode button |
3 |
Click on a contour.
4 |
Double-click one node to select all nodes.
5 |
Press Delete.
You cannot delete a path. A path is deleted with its object or
when all of its contours are deleted.
