Modifying lines and curves
You can edit the properties of lines and curves. You can reshape a curve by changing its nodes the shape of the contour at a node by changing the node type, by modifying its line segments on either side of a node, or by connecting line segments. You can also cut a line segment. When you cut a closed path or contour, you open it. When you cut an open path or contour, you create two separate contours.
| To edit a line or curve |
Edit workspace
1 |
On the Tools toolbar, choose the Pen tool |
2 |
On the Tool Options palette, click the Edit Mode button |
3 |
Select the shape.
4 |
Modify any of the settings on the Tool Options palette.
You can also edit the curve by clicking the Pick tool |
| To adjust a line segment by changing the nodes |
Edit workspace
1 |
2 |
3 |
Right-click a node, choose Node Type, and select one of the
following options:
Convert to Line — straightens the segment before and after the
node
Line Before — straightens the segment before the node
Line After — straightens the segment after the node
Curve Before — curves the segment before the node
Curve After — curves the segment after the node
| To connect multiple line segments |
Edit workspace
1 |
Create as many connected line segments as you want.
2 |
On the Tool Options palette, click one of the following buttons:
Start New Contour |
Close Selected Open Contours |
3 |
Click the Apply button |
You can save a set of Tool Options palette settings as presets.
For more information, see Using and creating presets.
| To cut a line segment |
Edit workspace
1 |
From the Tools toolbar, choose the Pen tool |
2 |
On the Tool Options palette, click the Knife Mode button |
3 |
Drag across the contour where you want to cut it.
When you click the Knife Mode button, you can cut through all
selected contours in an object.
