Editing gradients
You can change the colors, transition points, and transparency of gradients. You can edit default gradients or create your own gradients. You can also rename, delete, and save gradients.
The colors, transition points, and transparency of a gradient are indicated by markers and midpoints in the Gradient Editor:
Markers |
Midpoints |
You can add and delete markers, as well as change the transparency, color, or position of a marker. You can also change the position of a midpoint.
| To display the Gradient Editor |
Edit workspace
1 |
On the Materials palette, click the Foreground and Stroke
Properties box or the Background and Fill Properties box.
The Material Properties dialog box appears. |
2 |
Click the Gradient tab.
3 |
Choose the gradient you want to edit and click Edit.
| To change the location of a marker or a midpoint |
Edit workspace
Drag the marker or midpoint to a new location in the Gradient
Editor.
You can also click the marker or midpoint to select it, and then
enter a value in the Location field.
| To add a marker |
Edit workspace
In the Gradient Editor, click a position under the gradient bar or
the transparency bar.
The marker is created with the currently highlighted Fore, Back,
or Custom color on the gradient bar.
| To delete a marker |
Edit workspace
In the Gradient Editor, drag the marker away from the gradient
bar or the transparency bar.
| To change the color for a marker |
Edit workspace
1 |
In the Gradient Editor, click the marker below the gradient bar to
select it.
The triangle at the top of the marker turns black. |
2 |
Perform one of the following tasks, and click OK.
When you next apply the gradient that contains the foreground
or background color, it uses the current foreground and
background colors of the image (rather than the colors that you
used to define the gradient). To create a gradient that always
contains the same colors, use custom colors for all markers.
| To change the transparency of a marker |
Edit workspace
1 |
In the Gradient Editor, click the marker below the transparency bar
to select it.
2 |
Type or set a value in the Opacity control.
Values range from 0% (completely transparent) to 100% (opaque). At 100%, the underlying pixels are covered completely. |
