Using gradients
Gradients are gradual blends between two or more colors. You can paint, draw, or fill with gradients to create interesting effects or color transitions. You can use gradients to create Web buttons with shadows and highlights, to make objects look shiny or glowing, or to add dimension to objects. You can also use gradients to fade Web page graphics into other content, and you can use a black-to-white gradient as a mask.
For information about editing, creating, and sharing gradients, see Editing gradients and Exporting and importing gradients.
| To apply the current gradient |
Edit workspace
On the Materials palette, click the Gradient button |
The most recently chosen gradient becomes active. |
| To choose a gradient |
Edit workspace
1 |
On the Materials palette, do one of the following:
To choose a foreground gradient, click the Foreground and
Stroke Properties box.
To choose a background gradient, click the Background and Fill
Properties box.
The Material Properties dialog box appears. |
2 |
Click the Gradient tab.
3 |
Click the Gradient drop-list to view thumbnails of the available
gradients.
If necessary, choose a gradient category from the Category drop-list containing the desired gradients. |
4 |
Click a gradient thumbnail.
The drop-list closes and the gradient name appears above it. |
5 |
Choose one or more of the following options:
Style — lets you choose a Linear |
Angle — specifies the angle or direction of the gradient, from 0
to 359 degrees. This option applies to linear, rectangular, and
radial gradients only.
Repeats — sets the number of times (from 0 to 999) to repeat
the gradient pattern
Invert — inverts the colors of the gradient
Center Point — determines the horizontal and vertical
coordinates of the point from which the gradient disperses or
radiates. The distance is measured as a percentage of the fill
area’s width. You can change the center point to create fills in
circles or other shapes in which the center of the gradient is not
at the center of the object. This option applies to rectangular,
sunburst, and radial gradients only.
Focal Point — determines the horizontal and vertical
coordinates of the point where the foreground color of the
gradient begins. The distance is measured as a percentage of
the fill area’s width. You can change the focal point to create
fills in circles or other shapes in which the effective light source
is not at the center of the object. This option applies to
rectangular and sunburst gradients only, and is available only
when the Link center and focal points check box is unmarked.
Link center and focal points — assigns the same values to the
center and focal points. Unmark the check box to edit the focal
point separately from the center point. This option applies to
rectangular and sunburst gradients only.
6 |
Click OK.
You can also
Edit the gradient colors, transition points, and opacity
Click Edit to display the Gradient Editor dialog box. For more information about editing gradients, see Editing gradients.
Save this gradient as a swatch that you can access later
Click Add to swatches, type a name, and press Enter.
Access recently used materials
Right-click in a properties box on the Materials palette to open the Recent Materials dialog box.
Apply the current materials to all tools
On the Materials palette, mark the All tools check box. If you unmark this check box, the current materials are applied to the active tool only.
You can also move the center point by dragging the control
needle or crosshairs shown in the gradient drop-list. If you
unmark the Link center and focal points check box, you can
move the focal point by dragging the crosshairs on the
gradient.
| To save an edited gradient |
Edit workspace
1 |
In the Gradient Editor, click Save As.
The Save As Gradient dialog box appears. |
2 |
Enter a unique name for the gradient, and then click OK.
When you are prompted to confirm that you want to save the gradient, click Yes. |
| To create a gradient |
Edit workspace
1 |
In the Gradient Editor, click New.
The New Gradient dialog box appears. |
2 |
Type a name for the new gradient, and then click OK.
The gradient is created with two markers at 0% and 100% that
use the custom color.
For more information about gradients, see Using gradients.
| To rename a gradient |
Edit workspace
1 |
In the Gradient Editor, click Rename.
The Rename Gradient dialog box appears. |
2 |
Type the new name, and click OK.
| To delete a gradient |
Edit workspace
1 |
In the Gradient Editor, click Delete.
2 |
When you are prompted to confirm the deletion, click Yes.
