Increasing the color depth of an image
If an image has a color depth of less than 24-bit, you may want to increase the color depth so you can use a wider range of effect and correction commands, many of which only work on images with 16 million colors. Depending on the color depth of your image, you can also increase an image to 16 colors (4-bit) or 256 colors (8-bit).
To increase the color depth of an image |
Edit workspace
Choose Image ![]() |
16 color palette
256 color palette
RGB - 8 bits/channel
RGB - 16 bits/channel
Color depths not available for the active image are grayed out. |
If your image has a palette, for example if you have a 256 color
(8-bit) image, and you need to maintain the palette colors, you
can save the palette before increasing the color depth. After
editing the image, you can reload the palette. For more
information, see Working with image palettes.
If you are increasing or decreasing several images to the same
color depth, you can add a button to the toolbar that you can
click to automatically set color depth. For more information, see
Customizing toolbars.
