Replacing colors, gradients, or patterns
You can use the Color Replacer tool to replace one color in a selection or layer with another color. You can use brushstrokes to replace only those pixels that the brush touches, or you can replace all pixels of a certain color in a selection or layer.
You can set a tolerance value so that the Color Replacer tool changes within a given color value range. The Color Replacer tool also works with gradients and patterns.
You can also use the Flood Fill tool to replace all pixels of a certain color in a selection or a layer. For information about the differences between the Color Replacer tool and the Flood Fill tool, see Filling areas with colors, gradients, or patterns.
Why does nothing happen when I apply the Color Replacer tool?
You must select a foreground or background color that appears in the image. If there are no pixels that match your selected color, then no pixel colors are replaced.
For more information about picking a foreground or background color directly from the image, see Choosing colors from an image or the desktop.
| To replace a color, gradient, or pattern |
Edit workspace
1 |
On the Tools toolbar, choose the Color Replacer tool |
2 |
Choose the material (color, gradient, or pattern) that you want to
replace. Click the material to apply it as the Foreground/Stroke, or
right-click the material to apply it as the Background/Fill.
3 |
Choose a material to use as a replacement material. The
replacement material can be any material in the current image, or
you can choose one from the Materials palette.
If the material you want to replace is the current Foreground/
Stroke material, right-click the replacement material to set it as
If the material you want to replace is the current Background/Fill
material, click the replacement material to set it as the
Foreground/Stroke.
4 |
In the Tolerance box, set a value from 0 to 200 to specify how
closely the replacement material should match the material you
are replacing.
At lower Tolerance settings, only pixels with very similar colors are replaced; at higher settings, more pixels are replaced. |
5 |
Position the cursor over the area of a selection or layer that
contains the material you want to replace, and perform a task
from the following table.
To limit changes to a specific area, make a selection in the
image before using the Color Replacer tool.
