Retouching image areas by using brushes
You can retouch images by applying brushstrokes. Some retouch brushes mimic photographic effects, while others change pixels based on their lightness, saturation, hue, or color values. Some retouch brushes create effects that are similar to those produced with the color-correction commands. The retouch brushes are described in the following table.
Brush
Effect
Lighten/Darken
Increases or decreases brightness; affects the RGB or Lightness value of pixels
Dodge
Lightens and brings out details of areas that are in shadow (mimics the traditional photographic darkroom technique of holding back light to produce lighter areas in printed photos)
Burn
Darkens areas of the image that are too light
Smudge
Spreads color and image details from the starting point and picks up new color and image details as it moves, as though smearing paint
Push
Spreads color and image details from the starting point but does not pick up any new color or image details
Soften
Smooths edges and reduces contrast
Sharpen
Heightens edges and accentuates contrast
Emboss
Causes the foreground to appear raised from the background by suppressing color and tracing edges in black
Saturation Up/Down
Increases or decreases saturation; affects the HSL value of pixels
Hue Up/Down
Increases or decreases hue; affects the HSL value of pixels
Change to Target
Changes pixels based on a characteristic of the current foreground color on the Materials palette: color, hue, saturation, or lightness
Color Replacer
For information about the Color Replacer tool, see Replacing colors, gradients, or patterns.
| To use a retouch brush |
Edit workspace
1 |
On the Tools toolbar, choose a retouch brush.
2 |
On the Tool Options palette, set the brush controls.
3 |
Drag in the image to apply the tool.
For more information about setting brush options, see
Choosing brush options.
You can apply the opposite effect of a retouch brush by right-
clicking as you apply the brush to the image.
